It is currently Sat Jul 19, 2025 6:58 am
PostPosted: Fri Jun 27, 2014 5:06 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
So a friend if mine has asked me to do some repair work on this little beauty that her grand-mother brought over from Russian 100 years ago. It's in remarkably good shape. She would love to restore it to playable condition. It projects quite strongly and I have found no evidence of loose or rattling braces. I think it has some real potential to be a nice player if fixed up.
If anyone can provide some background info on this guitar, it's maker, it's era I would be truly grateful. Any sense of monetary value?
Here is my plan...pending my friends approval.
-neck reset. Has a bolt-on neck and it came off easily in under 2 minutes. That was a welcome surprise.
-refret and then level fretboard as the neck has a small twist and the current frets are too low and worn to do anything with.
-patch soundboard with spruce diamonds
-attach a thin bridge plate as there is currently none and the inside is getting chewed up...probably from the high tension steel string it had on it. ANY SUGGESTIONS HERE? It needs to go back to ball end classical strings.
-replace bridge pins. It currently has three different types of pins in various states of disrepair.
-one bridge wing needs to be glued down.
-tuners seem to be in pretty good condition.
I'd welcome any input from those of you more knowledgable than I. Yes, I will be using HHG
Doug
PostPosted: Fri Jun 27, 2014 5:13 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Another pic
Doug
PostPosted: Fri Jun 27, 2014 5:45 pm
First name: Ringo
The builder was Julius Heinrich Zimmermann: http://en.wikipedia.org/wiki/Zimmermann_(publisher) . I believe they made all kinds of instruments including some harp guitars.
Apparently the Leipzig branch was opened in 1886... the label mentions Riga as well, where a branch was opened in 1905, so it might have been made after that? I am no expert but I do love these little European-style romantic guitars...
PostPosted: Sun Jun 29, 2014 12:13 pm
First name: Big
Last Name: Jim
Beautiful Project ! Yes I think Ball end Classical would be a Must in restoring this . Wish I had it . Looking forward to following this Project
PostPosted: Wed Jul 02, 2014 9:49 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
No input on the restoration, Doug, but I too am looking forward to your approach and execution on this little beauty! Old instruments like this need to be restored or maintained, if only to show us why they have lived such a long life, and that builders from the past knew a thing or two that we can learn from.
Alex
PostPosted: Thu Jul 17, 2014 7:33 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
So here is an update but work continues
-cleaned the crud out go the inside with rice
-removed frets, flattened the twisted and cupped fingerboard
-dyed fingerboard (will distress to match aged patina later), new frets using HHG
-affixed 2mm maple bridge patch - 2 grams
-affixing up to 10 spruce diamonds to stabilize cracked top...HHG for everything
Doug
PostPosted: Thu Jul 17, 2014 7:34 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
More pics with before and after "rice cleaning."
Doug
PostPosted: Thu Jul 17, 2014 8:14 pm
Looking good so far! Neat little project.
PostPosted: Mon Jul 28, 2014 5:53 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
So we are all finished now. Here's a video of my friend Blair giving it a test run. Enjoy some sounds from the 19th Century!
[youtube]http://youtu.be/voV7JqmVckY[/youtube]
Doug
PostPosted: Tue Jul 29, 2014 4:42 am
Well done, Doug! [clap]
Now you have to think of a good home for it!
Somewhere it'll be looked after but still used.
